what is this crossover's function?
I've seen the same, with the resistances and caps inverted (caps instead of the resistances, and resistances instead of the caps)
but never this one
what it is used for?
Hi Bricolo
If we don't know more we can't definitely tell.
I.e. if it is driven by a low-impedance source then it is simply an integrator and the resistor from input to output is obsolete.
But I assume that there was more at the input and so we'd like to know more in order to be able to tell you.
One possibility would be part of a bandpass filter.
Charles
