I know this website is dedicated to DIY audio but I am curious what is currently the cutting edge of audio technology. This sounds like a simple google and read topic but as I am sure many of you have found if you have done that that the audio world is mired down in renaming, rebranding, hype and marketing. There is so much marketing that it becomes near impossible to separate the rehypeing of old tech from real new innovations without a huge investment in time and research.
So what is actually new in the audio world?
Smaller, cheaper, more compressed.
In lab settings, amazing work with multichannel. For the home, not so much- the market isn't there given system requirements.
SY said:For the home, not so much- the market isn't there given system requirements.
Which sys. req. are flashy as a Hollywood preview night, 1000 watts per channel, high WAF and of course, they want it all for under $100 🙄
(though some of that class-D stuff is getting there
Cheers!
Data 'visualisation' using 3D sound
You might be interested in the Allosphere project at UC Santa Barbara.
A 10m diameter perforated metal sphere within an anechoic chamber. 3D images (eg of chemical/physical/geological processes - basically anything) are projected onto the interior and viewed from a central catwalk. Data are also represented sonically in full 3-D surround(!) projected from the exterior of the sphere.
There's a brief video about it here:
www.ted.com/index.php/talks/joann_kuchera_morin_tours_the_allosphere.html
Homepage is: http://www.allosphere.ucsb.edu/
Sounds pretty cutting edge, and you can even visit - I wish it were closer to me!
If any diyaudioers in the region ever do, please write up the visit here!
Best,
Steve
Best,
Steve
