Are you referring to bracing speaker cabinets? Maybe you're talking about rib braces - using small lengths of wood attached across the inner walls to damp resonance.
Sorry, I had to make clear that I was referring to bracing speaker cabinets - not to to shelf or dental braces🙂
A shelf brace is one that fills the entire cabinet in one dimension (as a solid shelf does in any cabinet) but has areas cut out to allow air flow. Could be in the shape of a ladder I guess but not normally referred to as such.
Hmmm. Actually this is one of a few things which could look like a ladder. Or maybe they refer to a few horizontal bars... Anyway, aparently this is not a common term. Thanks!
Actually a professional cabinet builder told it. I just did not want to ask him. I hope no one find this too dishonest
Hopefully soon:
http://users.ece.gatech.edu/~mleach/vifa3way/
I don’t have much time to spend on box building though. Will see…
A shelf brace usually is oriented horizontially. A ladder brace could well be a shelf brace oriented vertically.
dave
dave
- What is ladder braces??
