NOTE:The Brain of Ampman is formatted by someone.
Therefore all the data is lost.
For the time being,
PLZ Tell the ampman what is meant by the term amplifier??
Until we may have found a backup drive to recover the data??
For the time being,
Something that has an energy source, and an input and an
output, the input controlling the output in some way and the
energy output being larger than the energy input.
A lever is not an amplifier. A throttle / gas pedal on a car is.
🙂 sreten.
🙂 sreten.
A system where the output is proportional in some way to the input.
Not neccessarily always an increase.
Ax=Y.
Ax=Y.
Amplifier = straight wire + gain
http://www.diyvideo.com/forums/attachment.php?postid=294591
Amplifiers usually split their gain into two areas: voltage and current.
In the above diagram the transfomer provides the voltage gain, the transistors the current gain. It runs in class A.
oxford advanced learner's dictionary says this:
amplifier: a device for amplifying sth, esp sounds or radio signals.
amplify: 1 to increase sth in strength or intensity, esp sound; 2 to add details to a story
Lets hope the big chip manufacturers & others overlook the second meaning of 'amplify'. 😉
djk said:In the above diagram the transfomer provides the voltage gain, the transistors the current gain. It runs in class A.
I prefer the 2nd kind: transistors for voltage gain and transformers for current gain.
Matjans,
you obviously have a different version of the Oxford dictionary,
although the differences are not big. In my version amplifier is
defined as I stated above, while the applicable one of the
definitions for "amplify" is "increase the strength of (voltage,
current etc.)"
It seems my version (3rd edition, 1985 revision) takes a more
strict and technical view, while your version is more in line
with general language usage.
Anyway, I suppose we are mostly interested in the technical
definition of the term here, not what a dictionary says. My
previous post was partially meant as a joke, since I wasn't
sure if the original question was seriously meant, and if
it was, it might easily lead to an endless philosophical discussion.
All,
I don't expect people to come to an agreement on this term.
For instance, does an amplifier have to amplify at all, or can
we also consider degenerate cases which actually has a gain
less than 1 for both current and voltage?
We certainly do not require a gain >1 for both current and
voltage, since otherwise neither a follower nor a CB stage could
be considered to amplify.
current etc.)"
All,
I think people are missing the point here, that amplifiers do not have to be restricted to descriptions of current and voltage?
Think of an amplifier as just a ssystem block with constant gain, with an input, and an output. Thats all there is really.
osey said:I think people are missing the point here, that amplifiers do not have to be restricted to descriptions of current and voltage?
Quite right, it is a system block, not necessarily an electric one.
However, that makes it even harder to define what is and what
isn't an amplifier. Is it required to be linear even in the ideal
case for instance? Mathematically it is a function from one or
several variables to one or several variables with certain
characteristics, but which ones? I suppose systems theory
has some general definition of the concept though.
We are getting more and more into the philosophical discussion
I anticipated, so the question is, what was the purpose and
ramifications of the original question?
I have worked with hydraulic pressure amplifiers in the Air Force. Presumably there exist also pneumatic pressure amplifiers, commonly known as "compressors"??
BTW, The second definition given above (to add detail to a story) seems to gain more and more priority in audio advertisement.
Jan Didden
A simple wrench could be seen as a torque amplifier. The longer the wrench, the higher the torque "gain".
Re: What is an Amplifier..??
On the other hand, a regulated power supply is essentially
an amplifier where the input signal happens to be constant,
the voltage reference, so this definitions tends towards
being circular.
I don't agree that a compressor is an amplifier, unless its
output pressure/flow is controlled by some input signal.
Hm, maybe it is after all, if considering it as a pneumatic
version of a power supply?
The wrench, yes, is it an amplifier, or is it rather some kind
of converter? I think it is analogous to a transformer, so
I would say it is rather a converter (scaling up one thing
and scaling down another by the same factor).
LesW said:A device or contrivance for modulating a power supply..??
being circular.
I am afraid that this wouldn't count. IMO an amplifier is a device that must have larger output power than is used to drive (i.e. not to supply) it.
Charles
Agree. A wrench is a torque transformer, not amplifier.
Peter
Not that I consider the US patent office an authority on
terminology, but here is their definition of amplifiers in
the case anyone is interested and has the patience to read it. 🙂
http://www.uspto.gov/go/taf/def/330.htm
Charles
wouldn't that depend on what you are amplifying? a wrench certainly amplifies the torque, and yours amplifies power (actually, it redistributes power on the load).
As Peter mentioned above the wrench is a transformer, i.e. a passive device.
An amplifier should be an active device that outputs more power (which it takes from some power source) than it is taking from its drive - (or control or whatever-you-call-it) input.
Charles
Charles
A wrench is like a lever - sort of. It multiplies the force but divides the distance by the same amount. Think of a reduction gearset. Power out equals power in. Slower but pushier.
- What is an amplifier??
