I am confused on what to get.
I am assuming the tubecad software doesn't do P-P or SE. is this right? or tubecad does P-P and SE and others.
any suggestion/feedback?
does the software also have like "schematic maker"? something like orcad layout.
thanks for the help
thanks for the help
There are two programs of interest to you-
1. SEAmpCAD - used in designing single-ended amplifier topologies. Buy this if you're into designing single-ended amps.
2. TubeCAD - used in designing many things, from cascode to white cathode follower. Buy this if you're designing one of those, in driver, splitter or whatever purpose, like preamp, for example.
ps. while the programs will generate the necessary schematic, it is NOT a schematic editor like what you described. There's a thread about schematic tools available.
