what drivers used in Jamo r909?
Chris, I was talking about the chassis of the bass driver, not the whole driver. The Jamo driver has quite another cone, surrond and magnet than the Exodus, but they both share the same molded chassis. This chassis is probably made in Asia and sold to different loudspeaker driver vendors around the world.
It can also be that this Asian manufacturer builds the whole driver
accordigng to customer specifications, using this chassis.
James, B&C, or more correctly, the maker of B&C drivers, is definitely involved in the 909 design.
I do not think that this 15NW76 is the one used in 909, the 909 drivers have lower moving mass, important in dipoles, 55 grams. Xmax is bigger, 13 mm, Fs is also a bit lower at 24 Hz and they also have a foam surround which the proposed driver has not.
Another thing I've seen is that, judging by the driver chassis appearance, Lyngdorf-Steinway also seem to use B&C drivers:
Steinway Lyngdorf - Model D Speaker.
I have succumbed and have settled with three paralleled Visaton W-300S in my dipoles, and I'm very happy with the sound.
Visaton - Lautsprecher und Zubehör, Loudspeakers and Accessories
