Hello
I want to build this:
http://www.valutronic.se/sq50E.html
I'll be using:
http://www.monacor.de/en/produktseite_suche.php?artid=2094&spr=DE&typ=full
and maybe, not sure yet:
http://www.monacor.de/en/produktseite_monacor.php?artid=3259&spr=EN&typ=u
Now, I don't know what crossover to use??
Any sugestions?
Thank you
PS: Happy Ortodox Easter ;->
I'll be using:
Any sugestions?
Thank you
try this
You may try the following. We used it in an 11 L resonant box with 130 cm wo + 25 mm tw (units similar to those you inform, but Seas brand).
Lopass: 2,5 mH series inductor (0,9 ohms resistance wire) + 35 microF parallel capacitor.
Hi pass: 7,3 microF series capacitor + 0,7 mH parallel inductor(0,44 ohms resistance wire).
Note: to balance units sensitivity was necessary to add a series resistance 4,7 ohms /10W to the tweeter at the hi-pass output.
You may need to change this value. What I do is measuring the output sensitivity of each one with a radioshack sound meter, feeding them with TV audio signal of a non broadcasting (or empty) channel, that gives white noise.
I am sorry but I am a poorman.
I hope this could work for you.
Kind regards.
Hugo
Kind regards.
Hugo
