What color wire nuts to use???
TheBigMastodon said:
What color wire nuts should I use to wire my magnetic ballast and lamp? I will be using the 120v input. Would yellow be okay?
NO, don't use yellow. That would certainly cause a 'tinting' of the image. I would use white or black, or even clear if you could find them.
:clown: ^^
I think the question is serious-and all you have to consider is the nut being appropriate for the wire sizes being used. I think colors and sizes can vary between manufacturers. The package should tell you.. I know absolutely nothing about projectors.🙂
don't make fun of him guys,
because it's possible that certain colors pertain to certain wire nut sizes.
so by asking what color, he is asking what size....
but he did admit he thought it was for different voltages and that's pretty funny!!!
so that's how they trick you New Yorkers into paying those 12,000 dollar a year property taxes.
Pretty ones! 😀
Seriously,I didn't think wire nuts had a color/size correlation?
I've seen the same size wire nuts in red,yellow,or orange plastic..
Maybe different manyfacturers use different colors for thier sizes,etc..
I've seen big and little ones in every color(even clear!)..I'm not sure there's a "standard" for them.
I know there's different 'types'..some with 'wings' to help twist them on,and some without,etc..
