Sealed or ported...and i cant find the minimum cubic feet required for my subs....
This is going ina suburban.....plenty of room...i have 2 15" Audiobahn Flame Q's, they handle 2000 rms per sub...i will push 1500 rms to each....
Now what box should i invest in, ported or sealed, i listen to rap mostly so....ne advice is greatly appreciated
to tell you what kind of box we need you need a set of T/s parameters. If the manual doesnt have them you will have to email audiobahn and see what they tell you.
audiobahn arent known for SQ so i assume you want max boom for your buck? in which case id say as big a ported box as you can fit, tuning well need to work out via the subwoofer modelling program WinISD.
what do you want here? 60/40 spl/sq?
since you have a suburban you shoudl have lots of room, and be able to tune low....this is good.
how low do you want this thing to hit?
