Weird clicking from IcePower 300AS1 while off
Hello,
I purchased a Kemper Power Kabinet which is a guitar cabinet with a Kemper Kone (Celestion IR Speaker) and as I found out an IcePower 300ASC or 300AS1. I actually got a replacement because the original was making a continual clicking noise (either constant, or sometimes with a repeating pattern), but the replacement makes the same noise.
Here's a video I made of the issue:
Any ideas what could be causing this clicking? Is it something in the design, a failed component, or something in my power system?
The surprising conclusion to this video will be that I blew it up by shorting the optocoupler...sadly I shut the video off 5 seconds before the smoke got let out :'(
But I'm still curious what might be causing this, and if I can manage to repair the board how I could fix this too (or if it would happen on a replacement 300AS1 or 200AS1)
Thanks for any and all ideas!
