Weak or failure-prone sovtek 5AR4 tubes.
An interesting issue has come up in my experience with using Sovtek's 5AR4 tubes.
I wish to find out if anyone else is having a problem with the cathode coating flaking off and shorting the tube.
I ran through a series of Sovtek 5AR4 tubes in a number of cases which had failed for no apparent reason. I kept concluding that too much power supply capacitance and/or amplifier malfunctions were the cause but these cases are becoming too common to be coincidental.
Please tell me of your experiences with these rectifier tubes, good or bad.
