Waveguide for XT25
I am thinking of experimenting with a 2 way using Vifa XT25 and Vifa P21 8" woofer.
Does anyone here know where I can find a suitable waveguide profile for the XT25? I will probably turn a couple on a wood lathe.
Cheers
Peter
Here you have some nice waveguides for the XT tweeter:
Waveguide VP158/5030 for XT Tweeter
If you don't "master" the German language, use google translation here: 😉
German to English
/Göran
German to English
/Göran
Damn they are expensive.
Would be cheaper in Europe to get the Dave Pellegrene (hope I spelled that right!) ones even if you were hit by everything the customs people could possibly throw at you.
If you are in North America I think the choice is a no brainer.
That said they look VERY solid indeed!
Spinmonster...
The elliptical ones you use look really good.
I was thinking of about 8" round WG purely for appearance sake, and possibly overlap the 8" woofer a la Troels' TQWT. How critical is the center to center distance for the 2 drivers?
Peter
I already have 32 ltr floorstanders built out of 7/8" cherry with thick mdf baffles. They have served briefly as test cabinets to accommodate different ideas. Trying to emulate my long standing reference Apogee Centaurs. The Vifa woofers cae out of the Centaurs when I converted them to reflex cabinets similar to the Slant.
I think a matching cherry WG on the black baffle would look rather cool.
Peter
Spinmonster...
Peter
An 8" with an 8" woofer is ok to 1600hz cross overs but there isnt a clean 8" woofer that matches the performance of the tweeter with a guide. I also see no low end benefit if it being used with a sub.
The elliptical is the perfect dispersion. At 10 feet there is no fall off standing on my couch or sitting on the floor so no performance gain is had by using a round one. Performance is supposed to be better limiting floor and ceiling reflections.
I call it the other way thinking the elliptical looks better. I ceretainly dont like when round ones are cut. His appears to use a 6" guide with a 8" midbass. They look good but not my taste
What the hell is that post above! My 2 years old must have posted it through my Ipod 🙁
BTW, I'm looking for possibility to run XT25 second order around 700Hz to 800Hz, and am looking for the cross section plan for the waveguide. Any one have such a drawing?
ADD: Twister WG seems to be too long for XT25?
The WG doesn't change the resonant frequency, but Peerless XT25 comes in many versions, be careful with them. There are tens of wgs matched for XT25, But it might be a little difficult to find cross-section to do cnc. User "jlaakso" has some for sale and he also might have a CAD-graph for them, PM him!
Tweeters | Tymphany
