I'm after a low noise regulator circuit which I can build at home. I want a circuit that is small and can be fitted inside my dac easily, taking up a minimal amount of space. There are 2 dacs each requiring there own +5v supply and also a pre 12v regulator.. At present 7805's are used, but I'd like a supply which offers lower noise than usual 317's etc. I know there are pcb's available for various designs but have shunned them on grounds of cost, considering I'm after 3!
Raja
Raja
I'm writing a series for TNT covering just that. Drop me an email at werner @ tnt-audio.com and I'll forward you the first installment which deals with measured noise in five types of regulators.
http://www.tnt-audio.com/clinica/regulators_noise1_e.html
low noise regulator
Hi, How about this site?
I also features the Wenzel Finesse circuit used by a local clock monger.
http://www3.sympatico.ca/add.automation/spice/ripple.htm
Site is not always on line!
HI,
can this be used for a +5v supply? If so how?
http://www.wenzel.com/documents/finesse.html
Raja
Raja
Why not?
Why not?Raj1 said:HI,
Raja
I have used buffered and filtered low-noise voltage reference as a supply for analog stages of my latest DAC. Nice thing about this implementation is that the power feed point is out of the feedback loop at audio frequencies - the supply looks like a passive RC source to the load. The opamp buffer is configured as a shunt regulator in my circuit, although series regulator is more common.
Burr-Brown has instructive application notes about this in their voltage reference section...
Re: Why not?
Hi Elso,
What I meant is that do any component values need to be changed for the lower power supply of 5v as compared to 15v?
Also should I bot be able to get the parts (transistors) in the UK can someone recommend plug in alternatives?
Raja
Elso Kwak said:
Why not?
Hi Elso,
Raja
Re: Re: Why not?
Hi Raja, Plaese enable your "email button".
Raj1 said:
Hi Elso,
Raja
- Digital Source
- wanted: suggestion for a low noise regulator circuit.
