Want a smaller lcd for your projector?
Small VGA and SVGA resolution monitors cost too stinking much, so I thought about stripping a projection panel. Projection panels often have all the inputs you could want, no backlight to worry about, and you know that there won't be anything blocking the light getting to the LCD, after all, this is what they are made for.
Projection panel LCD's are between 8 inch and 10 inch diagonal.
Sounds ideal for a DIY projector.
I did some searching on Ebay today (January 26, 2006), and found these decent LCD Projection Panels. At the time I found them, the bids were running from $10 to $50 plus shipping.
All of these are TFT color and have at least a powersupply included, most have all the necessary cables, too.
The first line is the title used on Ebay, so use that to search in ebay if you find one that you like.
MEDIA PRO NVIEW LCD PROJECTION PANEL PROJECTOR W/ CASE
640 X 480 YOU CAN HOOK UP TO 4 DIFFERENT VIDEO SOURCES, SUCH AS PERSONAL COMPUTERS, VCRS, TELEVISION RECEIVERS, PROFESSIONAL VIDEO CAMERAS, & S-VHS VIDEO PLAYERS COMP/SVID/RGBHV/VGA
nView View Frame Spectra C LCD Projection Panel
(2 of them) LCD panel resolution is 640 x 480 pixels.SVID, COMP, VGA
Two - View Frame Spectra C LCD panels
Two - AC adapters
Two - VGA cables
One - Remote control
One - Users manual
nView ViewFrame Spectra C 640x480 LCD Projection Panel
SVID, COMP, VGA. Inexpensive w/ flexible inputs
nView ViewFrame Spectra C LCD Projection Panel In Case
640x480 SVID, COMP, VGA. Inexpensive w/ flexible inputs.
nView SpectraPro LCD Projection Panel w/ Remote + Case
800x600 SVID, COMP, VGA.
Great color, no noticeable blur, nice panel.
nView ViewFrame TFT LCD display for overhead projecter
(The Yellow One!) 640x480
Get a MAC to VGA adapter (15-pin), and plug it into the "analog" input. Run the VGA cable from your PC to the adapter. Make sure that you go to your display settings, and set the resolution to 640x480
PROXIMA Ovatio 810 LCD projection Panel
2.1M 30-50ms, 200:1, VGA(NTSC/SVID/PAL/SECAM w/A194), Active TFT, VGA & S-video, 640x480
SHARP QA-1650 COMPUTER PROJECTION PANEL WITH CASE
640x480 16.7M VGA, RCA, SVID. Zooms to 800x600.
Sharp TFT Colour Computer Overhead Projection Panel (UK)
QA-1150 w/case + cables
Available inputs include a 15-pin VGA monitor serial port (Pc or Mac), and composite video.Active Matrix TFT LCD panel providing up to 1.7million colours.
640 x 480 pixels for clear sharp images.
SHARP COMPUTER PROJECTION PANEL
It is a QA-1200
640x480, 1.4M, VGA, RCA, active matrix
Sharp TFT Color Projection Panel QA-1750
640 x 480 (native) COMP, SVID, VGA. Poor interpolation at zoomed 800x600. Controls depend on inputs. Fast and good color.
Sharp TFT Computer Overhead Projection Panel QA-1750
Quote "Available inputs include a 15-pin VGA monitor serial port, composite video, S-video and three 1/8" stereo audio ports. " Unquote. 640 x 480
APOLLO VISION
It is an Apollo Vision 262k, 640x480 , I think it only has computer inputs.
It is listed strangely, so you can probably get it for 10 bucks plus the 12 dollars shipping.
In-Focus SmartView 3600 LCD Projection Panel V2
Supplied with custom heavy duty, foam lined carry case
Power adaptor, leads (Pc and MAC), Remote Control and Manuals. VGA, RCA 640x480
Tgreenwood
