I Iddo Member Joined 2019 2019-11-28 2:07 pm #1 2019-11-28 2:07 pm #1 Using W5500 UDP mode, read the received data size Len = getSn_RX_RSR (0), the program return value is always 8 bytes more than the actual send, it may be just a UDP header. Is it a problem with the underlying driver? nigelwright7557 Member Joined 2008 murtonpikesystems.co.uk 2019-12-05 2:27 pm #2 2019-12-05 2:27 pm #2 Quite often with data packet based systems they add CRC and length words. You need to look up spec and see what is expected. You must log in or register to reply here.
