I'm a very novice tinkerer, so I appreciate any of you taking your time to look at my project.
I want to tap between the amplifier and crossover of my Leslie 147 (organ amplifier) that I use frequently in live performance. I measured mezzo forte volume at 5VAC, and forte at >5VAC-22VAC (depending on how I drive my preamp), although other sources say it can go as high as 30VAC. My goal is to have LED strips in the top and bottom of the cabinet. The blue would be fully illuminated at no/low volume, and the red would be fully illuminated at high volume.
Oh wise ones, am I on the right track with my design? The potentiometer value at the voltage divider should demonstrate how little faith I have in my own math...
