Having an issue with the power supply in a Marshall tube amp after installing a new set of EL34 tubes. . During biasing I measured the plate voltage after letting the amp warm up for 15 - 20 min, volume down with a 4 ohm load (speaker) connected, it measures 470 volts to start than drops to 448 after a half hour or so, seem s the longer I leave it on the lower it goes. Just measured it again this evening, and it dropped and went back up to 467 at some point. I am thinking the power supply caps might be leaky, any input would be greatly appreciated.
Not leaky caps. Are you also monitoring the mains voltage? You have 120vAC mains, your B+ is not quite 480vDC. That is numerically about 4 to 1. And that means for every volt your mains changes, your B+ changes 4v. So if the mains moves 5 volts - something it does all the time - then your B+ will change 20 volts.
Just a possibility.
Leaky caps would leave you with excess ripple and thus hum.
Just a possibility.
Enzo, Thanks I did not think of that, it is summer and the the voltage on the primary of the input transformer is likely fluctuating, I will check that. Thanks so much for the reply.
To satisfy yourself that there is no problem lurking, measure the anode current to make sure it is stable.
Or approximately proportional to wall-socket sag.
I have 125V at the street, but I am 500 feet back on a skinny wire. While my A/C (the usual Big Load in summer) is tiny, when the dryer and hot-water run I am down to 113V, and can dip to 108 if other loads happen. This would be a much bigger change of B+ than your 470V-448V. Which is only say 125V to 119 wall-voltage.
