Voltage divider to reduce 6v dc to 2vdc
Hi Guys
I want to try a #30 triode in my preamp set up and have 6V available for the heaters. Is it feasible to use a divider to tap off at 2Vfor its heater at 65mA.?
What values of resistor should i use? In a floating heater supply which draws no current its resistances in the 100's of kOhm range but I thought I should seek advice re this.
If we are dropping 4 volts at .065amp then thats 0.26 watts so I should use 2 watt resistors.
Feel free to jump right in and point out what I have overlooked.
Other than Batteries, I just cant get a hold of a small enough tranny . At this point it is an experiment so if its succesful I will build a purpose specific regulator board for this
Just some basics.. not going to comment on if it is usefull to your project....
When you have two resistors in series, regardless of size the same current will flow through each one...
when you have resistances in series, the voltage will be divided in the same ratio as the resistances....
for example if you have a 4ohm and 2ohm in series and apply 6 volt over them, the 4 ohm will have a voltage of 4ohms over it, and the 2 ohms will have a voltage of 2V...
To prove the first observation 4V/4R = 1A and 2V/2R=1A
So now you know the ratios of the two resistor, and just need to limit the current to as much as you need....
I do not know the impendance of the thing you are trying to drive but I will assume it is powered by 2V and 0.065A, so useing ohms law I would say it is 2/0.065=30.76R
Anyway you have two things in series and you want one to be 2V @ 65mA, which means the other has to be 4V @ 65mA...
4/0.065=61.5R
Dissipation over this resistor is 4V x 65mA = 260mW, Half watt is enough.
PS.. look at PCB mount transformers for little matchbox footprint ones...
As Nordic has already given the answer as to which resistor to use, I will only give another suggestion.
The 6 is VDC, I assume. Use a LM317 set as CCS to feed the valve. The resistor value should be something as 18R (1.2V/0.065A), but you can also use a 22R in parallel with some other resistor, AOT (adjusted on test). Some people prefer the sound of DHT's fed from CCS.
