ok, i'm sure you seen this topic before but someone please explain this to me(relating strictly to subwoofers)
i've heard two sides to the story:
adire audio states here LINK that inductance in a subwoofer DOES have an adverse effect and SHOULD be a spec that matters in driver selection....what values are considered high and low..doesn't go into any kind of detail
now linkwitz, on his site, states that voice coil inductance has little real world effect on sub bass performance
someone want to help me out here?
I'm with Linkwitz on this one, at subwoofer frequencies
inductance is an issue that can be ignored, and it has
no influence on the transient response of the sub,
given the effect of the normal subwoofer filtering.
Adire Audios article stupidly ignores the effect of any
filtering applied, besides that its so wrong in its mis-
application of simplistic physics I don't know where
to start to correct it, best just to safely ignore it.
🙂 sreten.
🙂 sreten.
kan3 said:ok, i'm sure you seen this topic before but someone please explain this to me(relating strictly to subwoofers)
Sure, voice coil inductance affects the transient response, in the technical sense. So does the crossover filter, to a much higher extent. It is not important. What the woofer does not produce in terms of sharp onsets, will appear in the midrange and/or tweeter.
The importance of transient response is IMO greatly exagerated. The relation what the technician calls good transient response when he/she looks at the waveform and what the listener perceives as "quick response" is far from 1-to-1. I am not saying that different speakers can be perceived as having different responsiveness, I just don't think the transient response (as the technician sees it) is the explanation.
Focus on frequency response instead, that is far more important.
I just don't think the transient response (as the technician sees it) is the explanation. Focus on frequency response instead, that is far more important.
They're one and the same, bolstered by a couple of centuries of transform use. I think the analysis at the link is largely doo-doo, but rather than get bogged down in theorizing, it's easy to test the assertion- take one of those high inductance woofers (their definition of "high inductance" is unstated) and measure the near-field frequency response when excited by a normal low source Z amplifier. Oh, it looks like it's not rolling off below 1kHz? My, my, whaddaya know!
... and just when you think that you've heard it all ...
subwoofer transient response?
I agree with Svante and SY.
woofer speed
LOL the old wives tale returns
its Box resonances
resonance over ring
room resonances
peaking ports , etc
that do the yuck sound! Focus on the majors
The ONLY Thing i can think of to do with high LE is that some one stated that you get IMD if operating the woofer near its roll off-but who runs their subs full range ?
jbl runs their 15"s up to 1khz but they have low le anyway.. 😉
its Box resonances
resonance over ring
room resonances
peaking ports , etc
Hi all, perhaps a bit of clarification...
Many times, people bring up the old myth about the "acceleration factor", BL/Mms, as proof of why one driver has better transients than another. In fact, this factor is nothing but efficiency, which has ZERO relationship to transient response. This is why the paper was done in terms of acceleration and how accleration is SPL, not transient response (rather, the rate of change of acceleration is transient response).
As far as subwoofers go, many of the higher excursion subs out there have inductances in the 5-6 mH range. With a 3 Ohm DCR, this puts the inductive roll-off around 100 Hz. Sure enough, the inductance of these drivers definitely affects the transient response, even with a crossover at 100-150 Hz (in essence, you have another order of crossover).
Anyway, of course the crossover can have a major impact on the transient response of the system; that is not challenged at all. if the crossover is within the pistonic passband, then it is the main limiter of frequency extension (transient response). However, when talking about the raw driver itself, it's not mass or BL that is the limiting factor (and hence not that BL/Mms thing) - it's strictly the inductance that sets your bandwidth/transient response limitations.
Please understand the paper is written for your average car audio person, who probably never stopped to think that a voice coil is essentially a high DCR inductor! Thus the simplistic terms and method to explain why it's inductance that matters, not mass or BL or any other factor.
Dan Wiggins
Adire Audio
Dan Wiggins
Adire Audio
The Peerless CSX 10" has an Le of 2.9mH.
The Peerless XLS 12, (5 ohm version) has an Le of 4.2mH.
The Adire Shiva Mark IV has an Le of 2.12mH-much less.
Both Peerless drivers have an aluminum shorting ring.
The Adire Shiva does not.
Does this affect transient response?
PS: The Peerless CSX 10" has a smooth frequency response to above 1.5 KHz.
PPS: How much does this difference make, if any, if you are going to cross over between 100 Hz and 200 Hz in a typical subwoofer application?
Keltic,
A shorting ring can affect nonlinear inductance based distortion (typically even order components from Le varying as the driver moves forward and backward). If it lowers inductance, it will inherently affect transient response.
For a typical subwoofer with these specific drivers, it really doesn't matter. However, for some subs - and for some midbass applications - it does matter.
Again, the idea was to bust the myth of "BL/Mms = transient response".
Dan Wiggins
Adire Audio
Dan Wiggins
Adire Audio
DanWiggins said:Keltic,
If it [shorting ring] lowers inductance, it will inherently affect transient response.
Dan Wiggins
Adire Audio
Okay, but if the shorting ring does lower Le, will that show up on the Le spec?
In other words, for crossover purposes, is a sub with a spec of 2.9mH and a shorting ring equivalent to a sub with a spec of 2.9 mH without a shorting ring? Or will the shorting ring cause the sub to somehow act like it has less inductance than is listed, in reference to crossing the sub over at 100 to 200 Hz?
I realize these are not your woofers with the shorting ring, so you are not really responsible for answering that question. 🙂
DanWiggins said:Hi all, perhaps a bit of clarification...
Dan Wiggins
Adire Audio
In these terms your article does make sense in trying to debunk
one myth, which is fair enough, but these terms were not given.
But a right doesn't justify a wrong, and talk of infinite transient
response etc is entirely misleading, and only possibly applicable
to tweeters or the like.
The simple fact you appear to be alluding to is many subwoofers
have an intrinsic bandwidth, and any attempt to use them outside
this bandwidth, or lack of consideration of this bandwidth, will
impair the resultant frequency response and by definition transient
response.
Its extremely true a driver with a bandwidth far exceeding its
required range will perform within range, converting this to
transient response arguements is pointless and misleading.
Finally it is simply not true the inductance is the only indicator
of transient response capabability, but this is entirely irrelevant
for subwoofers.
Also I'm not aware of the arguement you are trying to debunk,
but it seems to allude to efficiency, which like it or not, is nearly
always associated with good transient response, high efficiency
= good dynamics, which is most of the time true.
🙂 sreten.
Sreten posted:
Note that many times manufacturers - especially in the prosound and some parts of the high end world - will "fudge" bandwidth by publishing highly smoothed response curves. What you see is not only the bandwidth of the driver, but it's often artifically extended by cone breakup. Smoothing out cone breakup can make the driver appear to have more bandwidth than it really does.
I think many times people associate dynamic drivers/light drivers as "fast" for a couple of reasons:
1. They tend to often have hotter top ends than low ends (biased towards the higher end of the spectrum) which can make it sound wider in frequency response than it really is.
2. Often the inductance of high efficiency drivers is low, because voice coils are heavy so they are wound as short and small as possible. It's the search for high efficiency (low moving mass) that lowers the inductance, and as a result bandwidth is increased. It's not because of the efficiency itself, but an side-effect of the need for low mass that gets you the low inductance.
Thanks,
Dan Wiggins
Adire Audio
Fixed now...🙂In these terms your article does make sense in trying to debunk
Which is why we were careful to make it a theoretical extension - IF you could slew the current at an infinite rate, you'd have infinite transient response. Driver size/application is irrelevant - is the operation/relationship of current changes to transient response that are being described.But a right doesn't justify a wrong, and talk of infinite transient
Correct. I don't see the problem here... Operating outside of bandwidth inherently means you don't have the transient response to provide the bandwidth?The simple fact you appear to be alluding to is many subwoofers
response.
I'm not sure I follow... If you're within the bandwidth of the driver, then all is OK. If you're outside the range (past the inductive roll-off), then you don't have the bandwidth. And you will also be limited in transient response (Fourier transform). Of course, the paper was more about to describe WHAT limited transient response, rather than what wide transient response implied.Its extremely true a driver with a bandwidth far exceeding its
For a raw driver, I don't know what else limits transient response. If you could shed some light on this, I'd be grateful!Finally it is simply not true the inductance is the only indicator
for subwoofers.
Dynamics aren't transient response, however...😉Also I'm not aware of the arguement you are trying to debunk,
but it seems to allude to efficiency, which like it or not, in nearly
Thanks,
Dan Wiggins
Adire Audio
Hi DW,
I don't really want to go into whats relevant as an arguement.
You are correct the transient response arguement is only a
transform away from the bandwidth arguement, but I'd suggest
for your less than well informed types the article is supposedly
intended for the bandwidth version is a lot more straightforward.
My point about the bandwidth of subwoofers is that most
do have the bandwidth required, except for the silly ones.
I quite agree dynamics isn't the same as transient response 😉,
but again I'd suggest your misleading your less than well
informed types with an arguement they will misunderstand.
Finally a voice coil has an effective mass. So does a driver cone,
but importantly this reduces with frequency, the high frequency
roll-off is simplistically defined as when these are equal.
So the cone / voice coil interface defines hf bandwidth and
transient response, not the simple voicecoil inductance,
🙂 sreten.
🙂 sreten.
- voice coil inductance VS transient response
