Hello
Has anyone used these MKP capacitor in a project
I tried searching for them online review and have not found
VISHAY SPRAGUE - V-735P
Hello
I've tried them as input coupling cap on my My_MyRef variation.
They're honest and good sounding caps.
Thanks bro 🙂
Currently I have a 2 capacitor VISHAY MKT1813
10UF
as a output caps
on a diy project of my dvd denon 2900
I am very happy with them.
The question of whether the MKP735P
Will be much better
mkp vs mkt
Thanks bro 🙂
You're welcome.
Will be much better
mkp vs mkt
Never compared the two so I don't have any clue on sound difference but, specwise, the MKP is way better than MKT.
I've got MKT 10 uf 63 volt as coupler caps in my Hammond organ preamp. As the organ only generates frequencies up to 7 khz, this is not a demanding application. MKT is polyester dielectric. John Curl, other senior diyaudio posters, much prefer polyprophylene as a dielectric for capacitors in the sound path. They say it is more linear. I don't have a stocking source of MKP with a broad line that will ship 1-2 days surface for <$6 like newark will. The MKT were expensive enough at $2.10 each. My organ has 6 preamps and I used a dozen of them. The MKT did sound way better than the dried up 1967 electrolytic caps previously installed, restoring bass response and imparting sparkle to the glock and xylophone "percussion" (attack) features.
edit, the bag says MKT and polyester dielectric.
MKP is polyester dielectric.
While there's no established standard usually MKP is used for metallized polypropilene and MKT for metallized polyester.
Wima MKP10 is a metallized polypropilene cap.
I'll buy the 735P
And I will do a comparison between
MKT1813
To
MKP735P
And I'll report on the results 😉
I'll buy the 735P
MKT1813
To
MKP735P
I have access to both MKP and MKT types.
I have used them to replace old phase splitter caps in vintage cinema amplifiers.
I measured them at 500V and the MKTs came in with less leakage however both types were well up into the 10s of gig ohms.
I tested all of them as the valves are expensive EL37s and the output transformers would be costly to rewind.
The capacitor of VISHAY MKT1813-10UF
After a Running of 50 hours
Really excellent
Accurate and detailed
Especially at high frequencies
I order
VISHAY MKP 735P-10UF
And I showed how there is a difference between
- Design & Build
- Parts
- VISHAY SPRAGUE - V-735P
