Virtual Battery PSU
Hi!
Could somebody tell me how to adjust this circuit for lower output voltage??
e.g. 180Vdc and 100Vdc? It has now 270Vdc on the output. (info from Andrea Ciuffoli"s great site)
Greets:
Tyimo
Since zener diode D5 is a voltage clamp which protects MOSFET Q1's gate-to-source thin oxide, I would have expected that Q1's source would be on the output side (connected to R6), while Q1's drain would be on the input side (connected to R1).
However the schematic is drawn the other way, with Q1's source = input, and Q1's drain = output, and clamp diode D5 from gate to drain. Jeepers!
