Vifa M26WO-06-08 specification
I have 6 of these that I bought, um, 20 years ago 🙂 for a home theatre setup. I was recently googling them, which resulted only in a bunch of people looking for their specification because they were used in the Martin Logan SL3. They're a compound-paper-cone 10" woofer which work well in a sealed box but are lacking in sensitivity and (by modern standards) Xmax.
For the purposes of posterity and future googlers looking to repair an SL3, this is the Thiele-Small specification that I copied from the datasheet when I bought mine:
Vifa M260WO-06-08
Fs = 23.3 Hz
Qms = 2.63
Vas = 150L
Cms = 0.893 mm/N
Mms = 52.28g
Rms = 2.91kg/s
Xmax = 6.5mm
Diam = 209.3mm
Sd = 344 sq.cm
Qes = 0.62
Re = 5.84 ohms
Znom = 8 ohms
BL = 8.5 T.m
Pe = 130W
Qts = 0.5
eff = 0.209%
SPL = 85.4 dB@1W
I have not confirmed these numbers with measurement; doing so now with my now new-old-stock drivers may well be misleading for people who are looking for a new driver to match what these things were when new. Hope that helps someone out there...
