Viability of Infinity IRS Beta's today?
I'm curious if an old set of Infinity IRS Beta's can hold water against speakers today? Can they even be restored? I know of a set that has been in storage in there boxes for a great many years. I would bet that the woofer foam has all rotted out at this point. But that can be redone fairly easily if the woofers still work, and most importantly if the servo woofers still work!
I have no idea what sort of condition they are really in as it would be quite and undertaking just to un box the things. refoaming the woofers is about $20 each x 8 so you would be shy of $200 right off the bat. and then there is no guarantee the panels are all working.
Do these hold any value still today? would they be worth pursuing??
Zc
Hey ZC, glad to help out. To be honest, I am jealous of you. If you get them for a good deal, even if you spend $1k or so to repair the woofers, if the rest of the drivers are good, you just purchased what is regarded as one of the best speakers ever made. Good Luck!
Peace,
Dave
I'm pretty sure it is this model infinity that changed my view of audio for ever! My memory was that there were 6 12" woofers per side, but I've never found an infinity speaker with that so I think that memory is false.
The sound was so clean and pure, the soundstage was amazing I felt that Jennifer warnes was in the room singing live.
I went home and listened to my lowly system and almost cried.
The speakers alone were $35,000 AU. This was sometime in the early nineties I think. The entire system that had been set up I think was over $100K AU
It was the first (and only) high end system I have heard. I swore I would not listen to another unless I was able to afford something as good 😉
Tony.
Wintermute - The IRS Betas were around $12k US in 1990, 4 Watkins woofers per side. The IRS Reference Series sounds like what you heard. I still have my Beta's, do not listen to them as much as I did when my VTL300's were running the electrostatics (I think I blew up a transformer), I have an old Adcom & SAE A502 standing in temporarily. They are everything people say, but when driven properly, voices & strings in particular will surround you with pure magic.
Hmmm I suspect what I saw/heard may have been a special order. I'm 99% sure that the non-bass columns were electrostatics (pretty much the same height as the woofer columns), but they were paired with the 6 X 12" woofer columns.
Tony.
Anything is possible; electro-statics are in both systems, but very different cabinets.
With the Beta (4) 12" speakers, the matched columns all stand about 5 1/2' tall, so you are going to need a very tall ceiling for the (6) speaker columns. Here is a quick pick of mine, 8' tall ceilings, pardon the mess.
picowallspeaker - Not even close to being qualified to comment on acoustics, much less cylindrical waves. At first I assumed you might be referring to the potentially negative acoustic properties of my rock fireplace - but hey, uneven surfaces are supposed to help cancel standing waves, no? :~) After some googling, I note an article on line arrays (see below) that sort of sounds a tiny bit like the theory behind the Servo & woofers sharing each cabinet.
Can Line Arrays Form Cylindrical Waves? A Line Array Theory Q & A
The story I heard was that you can get lower / punchier frequencies either by using larger diameter cones, or by somehow achieving more cone movement; these do the latter by way of the servo unit. Actually, I was surprised when I had them re-foamed by Watkins recently, only one of the woofers gets wired directly to the servo with special terminals, then it & the other three are wired up with the normal speaker hook up terminals, in series.
There is certain program material that can punch you in the stomach with a quick bass frequency, if the volume is up high enough. But I prefer voices & strings. Peace.
