VGA Converter not working?? nView z210
I am fairly new to the DIY projector and am starting with the OHP/LCD Panel approach. I bought a Dukane 4003 which is great and an nView Z210. The panel works great thru a PC, lots of colors and good resolution but there are no AV inputs on this model.
So I found a converter on ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5724249616&ssPageName=ADME:B:EOAB:US:6
I hooked it up and tried a camcorder, a digtal camera and my cable box and I get the same result everytime. The image comes thru fine but it seems to be monochrome and there is a sort of a "flicker" of horizontal lines that seem to contain color on different areas of the screen.
I searched thru the forums and couldn't find an answer. I tried it on a regular PC monitor and get the same results.
Does anyone know why or have heard of this before?
Also would a TV3000 or equivalent help?
Is it a frequency problem? If so, how do you change the frequency on the panel?
Aby help would be greatly appreciated.
tcp
