I'm looking for a 4 wire cable with 1-2 mm outer diameter. Currents are in the mA range so resistance is of minor importance. This is for use in a product, not audio.
Does anyone have any source for this?
Does it have to be screened?
Jan
ultra-thin insulated wire - Google Search
My Google search might give you a few ideas.
32swg enamelled copper wire is insulated and pretty thin.
I have some 1mm OD wire, wire dia is 0.5mm.
I don't know the quality of the insulation, but the NATO Stock Number is 6145-00-485-0270 ;-)
NSN 6145-00-485-0270 Wire, electrical | New Century Components
Happy to send you some.
Jan
Jan
Jan
BTW The 0.5mm solid core wire is silver plated.
Jan
Isn't he looking for a four core cable, not for a single wire?
When at home this evening, I'll be looking for some tonearm cabling that fits the task.
Best regards!
Best regards!
It would be easy enough to make miniature multicore with the suggestions that I have made already.
That type of wire is common inside headphones. You would need to do some searching and most likely it would be from a chinese vendor. Gore has some stuff and could make it but only if you need a lot.
A division of AKM has an elastic wire that may be a good fit if some stretch is needed.
Your suggestion seems to be 1-conductor wire?BTW The 0.5mm solid core wire is silver plated.
Jan
Yes. Do you need 4 wires within that dimension??
In that case I would look for kynar wirewrap wire and twist 4 wires.
0.25mm 30AWG Insulated Silver Plated Single Core Copper PCB Kynar Wrapping Wire | eBay
Jan
Jan
Radical thought, flatflex cable such as: A9AAT-0406E TE Connectivity AMP Connectors | Cable Assemblies | DigiKey
Hi Peranders,
Here are a few manufacturers I've used in the past:
PVC Multiconductor Cable
Flexible Wires Cables | Micoflex Wire and Cable | Custom MadeFlexible Wire and Cable
MOGAMI® - Ultraflexible Miniature Cables
#2479 DAFLEX Ultra-Flexible FEP Subminiature Cables
Hope this helps!
-Len
Hope this helps!
-Len
- Design & Build
- Parts
- Very thin 4 wire cable
