VERY old transistors for free!
Joined 2003
Hi all.
I've been given a number of old (germanium-transistors).
Half of them have never been used and I would guess that they are in good condition.
I have no use for them, but there seems to be some hype about these and I would like to offer them to you guys.
Types are (amongst others)
AC176, AC128, AC125
BCY34
OC71.
I guess that there are around 30 in all.
I can post pics (germanium-porn?)
Some one has obviously taken great care of these for many years and I would like to "honor" this by giving them to people at DiyAudio.
If the transistors are worth anything I would like people to donate some money to DIYA and I'll send the transistors for free.
So, post here if you feel that you have a "worthy" project.
If I dig more stuff up, I'll post it here.
Regards TroelsM
I'd be interested to measure them. However, they may not work. I tried measuring a GET1 recently but when I opened the sealed packaging, it turned out not to work. Poor seals on the transistor had allowed water vapour in and killed it. Shame.
Update
Hi.
I also found these. - I've never seen anything like them before.
Regards TroelsM
I used to use an AWA regulated power supply with 2n442s in it ( my memory may be failing me but they were something like that). The thing was built mostly point-to point, the whole thing was made like they were expecting valves to go in it. Was still running beautifully when I left the company 3 years ago.
4 of them were good for 10 amps at 13.8V. they might be good for a little retro class A amplifier.
Hi TroelsM
Those AC176's might be valuable!
Back in the days of geraniums (sweet scented...) the AC128 was pretty much an OC81 update. The transistor sold as its complement was an AC127. It wasn't. If you ever tried to design a complementary 9V tranny radio output stage the gain fall-off of an AC127 was pretty poor, and you had to push the driver current somewhat to guarantee it would work. The AC176 was a "true" complement to the AC128 and you could successfully design the proverbial 1W amp. with it.
You have to go some to make a silicon tranny amp work like the AC176/AC128 pair. It is possible, but you need something special. For example, a BC327/BC337 pair CAN do 1W but run out of steam (a bit like the AC127) but a double pair of BC327/337 will do 1W. But then you've got the Vbe to limit performance unless you use a bootstrap on both sides; then the gain is still a little low.
But there again who uses 9V tranny radios these days with 1W/channel?
cheers
John
Well, thanks for making me feel like a senior citizen. One of my first electronic kits was one of those 26-in-1 setups with a breadboard from Philips- got it for my 11th birthday. AC126 and AF116. I had just built a little preamp with CK722 and was intrigued by these European units. Nice find!
