For those not happy with the AD817, try the AD8651 opamp. Estimated 0.5 uV rms noisr 1 MHz bandwidth powering a Tent Clock using extra local decoupling!
Nothing wrong over 400MHz bandwidth on a scope.
Hi FMAK,
Are you sure about the Part #, the AD8651 is a CMOS part with a 5.5V max PSU, and is more noisy then say a 5534 😕
John
John
----------------------------------------------------------------------------------JohnW said:Hi FMAK,
John
Read the data; 2.7 V; fine on 5V single rail.
Much faster than 5534; quieter than the AD817.
Yes, I am sure, I have done the two meausrements. Does the 5534 work at 5V' don't htink so. I am referring to the ALW implementation which powers the opamp from the output.
