I modded a cd 880 with kwak clock 7, reclock to dac (5.8Mhz) and dem reclock. Replaced lytics with sanyo oscons near dig chips and dac. Also exchanged 6 dividercaps 3 per channel from 0.1 to 1 uF MSB, 1uF the one after, and 0.47 the next. Rest kept 0.1 uF.
When playing music i hear very faintly a sort of lispeling noise (like a FM tuner) around low level music. In special when bass tones come in.
The separate IV/buffer pcb (a professional mod) is above the dac, connected with non shielded cable from dac. When i turn and move this pcb no change of low level noise.
I changed dem again to a cap, no change. So must be the divider caps or chip decoupling.
Anyone a suggestion what this could cause?
Scoped around: Without clock: Gnd is allmost quiet, as good as.
With clock: 100mV of clock remains and spikes on the gnd screen. Horrible. Tried different gnd of kwak spots, no difference.
Will try a tent clock and if possible on separate x former, choked, and see if it can be canned.
A simple magnavox player was used to compare, that one is allmost silence. Must say the dem pins shows a lot better signal on the cd880 with dem reclock. But 100 mV noise.....
I previously modded a cd304mk2, wherein the kwak could get a nice separate place inbewteen cast aluminium. There i had no problems.
