Hello,
To match my JX92S TLs, I plan to create a central speaker for my AV system based on a 2 JXR6 linear array. (And later on use single JXR6 for surrounds)
JX92 isn't an option because the central speaker will be behind the projection screen, and I've not a big depth available.
How would you setup the array? Vertical or Horizontal ?
Is an array required ? I feared that a single JXR6 woukd be too small for a central speaker.
Is it possible to design an ultra-fat enclosure without getting reflection on the back of the cone ?
Thanks for your help
François
François
I'm not an expert in Jordans. If it were my system, I'd consider using a JX92s with one of the small vented cabinet designs available. The center channel is very important and it might be better going with a proven design.
Just a thought.
-David
Just a thought.
-David
More my field as I have JXR6s and JX92s.
The 92s sound bright when listened on axis, so I think if used for a centre speaker you might want to aim them up (or down) to balance that a bit.
The JXR6s sound better, particularly in the HF. They are very clear and natural, particularly on voice. As center speakers they would work very well. I would use two vertically, to prevent any comb filter effects as you move side to side in the listening position.
They work fine in a shallow box. Keep the box size to the recommended volume on the Jordan site (2 to 4 litres per driver). Watch the impedance - they are 4 ohm so you'll want them connected in series to bring them up to 8 ohm.
Hope this helps.
Hope this helps.
Good points. Also look at commercial center channel speakers. A lot of them are angled up slightly.
-David
-David
is the JXR6 finally available again? I have not yet received any notice that they are...
if not, you could consider the square version of the Markaudio Alpair6
Thanks.
I'll go for the vertical array.
This will also be the opportunity for me to try the JXR6 and compare / JX92S.
François
François
You'll find the JXR6s very nice sounding. Completely natural with none of the slight emphasis the JX92s display on some material. It's important to put them in the right size boxes though - I had someone contact me recently who was worried about excess excursion and then revealed they were in 10L boxes!
- Full Range
- Vertical/Horizontal 2 x JXR6 Linear Array as central speaker ?
