Verry good CD transport
Im selling my Cambridge 840c cd player transport. I always used this for transport becose it was milles better than my audiomeca mephisto. The player is in like new condition with original packing, manual, remote and power cord. The price is low becose one chanel if you use this for cd player is about 40-50% lower in output volume. I already have buy this player with this defect from my good friend. I never trayed to solve or repair this defect. But for transport it is truly verry, verry good and top sounding. Price would be 200eu plus 19,80 euro shipping inside EU.
Hi, yes if used for transport is working without any problems, iv used this with my M2tech young dac for almost two years without problem and like I say the sound is truly top notch. Iv used it with spdif coaxial cable.like in description wrote, it also working like cd also, but the left chanel is for a half lower in output signal, why I dont know. Look on pictures you will see the back side of the player where all conections are.
Spec
RESPUESTA DE FRECUENCIA20 Hz - 20 kHz +/- 0.1 dB
THD @ 1KHZ 0 DBFS<0.0008%
THD @ 1KHZ -10 DBFS<0.0004%
THD @ 20 KHZ 0 DBFS<0.0007%
THD @ (19/20 KHZ) 0 DBFS<0.0002%
LINEARITY @ -90 DBFS+/-0.5 dB
STOPBAND REJECTION (>24KHZ)> 120 dB
SIGNAL TO NOISE RATIO A-WTD> 113 dB
TOTAL CORRELATED JITTER> 130pS
CROSSTALK @ 1KHZ> -130 dB
CROSSTALK @ 20 KHZ> -114 dB
OUTPUT IMPEDANCE> 50 ohms
DIGITAL INPUT WORD WIDTHS SUPPORTED16 - 24 bit
DIGITAL OUTPUT WORD WIDTHS SUPPORTED16, 20, 24 bit
DIGITAL INPUT SAMPLING FREQUENCIES SUPPORTED32kHz, 44.1kHz, 48 kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
DIGITAL OUTPUT SAMPLING FREQUENCIES SUPPORTED32kHz - 192kHz pass through (including 44.1kHz for CD) 48 kHz, 96kHz, 192kHz upsampled
AUDIO OUTPUT UP-SAMPLINGFixed 24 bit, 384kHz
DIMENSIONES (ANCHO X ALTO X FONDO)430 mm x 115 mm x 360 mm
PESO8.5 kg
