For Sale Various projects, spares (DDDAC, Kevin Gilmore designs)
Things you have for sale.
Joined 2014
Hello.
I have too many projects with too little time.
1- Two PCB for Kevin Gilmore's Dynalo MK2 "through hole", populated and in working condition.
It has to be adjusted with the final PSU.
Mix of Takman REY and Dale resistor. THAT340 input stage, genuine MPSA06/56.
90 € with EU shipping
2- Two Kevin Gilmore's UBAL/BAL boards, "through hole"
Same parts flavor as above, with Silmic caps.
60 €with EU shipping
3- One toroid 230v, two 25v secondaries, electrostatic screen. Hand manufactures on the UK, new never used, just tested.
60 euros + shipping
4- A pair of USSA amp, suitable for both USSA3 and USSA5 buildings. Populated for an avorted USSA3.2 project. Uses mainly Dale resistor, and features matched genuine NOS Toshiba Jfets. Does not incluse the heatsink-mounted transistor. 150 for the pair, shipped in EU.
Will provide Fab's documentation with the boards.
Ready to be used if you go the USSA3 route: just solder the second stage transistor and output LatFet, no other parts missing.
5- Four RIFA New old stock PSU capacitor, 33000 uF 70v. Huge! 20 euros per piece without shipping
6- Krell KSA-5 "clone", Class A headphone amplifier, Kevin Gilmore PCB, original parts and fully working.
Cased in black Modushop, with Schaeffer panel work (same company as frontpanelexpress in the USA).
Toroid with linear PSU (original style with TO3 transistors), and Alps volume pot. A pair of RCA input, output is 6.35 Jack and 4 point XLR to suit every cable termination.
Was one of my first DIY project, so decent work even if casing job and layout inside can be improved, price reflects that.
Original circuit, without the recent proposed revision to improve bandwith detailed here.
350 euros, shipping to be discussed (about 10 Kg).
Regarding the DDDAC kit, I forgot to mention that Wima bypass caps are replaced with polypropylene sulfide caps, that the 6k resistor to ground is replaced by a CCS (described here), and that a buffer board is provided, enabling the use of transformers with only one DAC board (described here).
