Variable SMPS
Joined 2003
Hi All.
I've got a couple of old Lambda powersuplys capable of 120V/1.7A. Problem is that both are dead due to a fault in the potentiometer controlling the voltage.
Well. One solution is to fix it, but there's a number of design-issues and I would rather use some of the components to build something else.
So. I've got 2 transformers capable of something like 120V AC / 300VA with caps (2200uF/200V).
In the junk-case there's also a lot of mosfets, all kind of heavy ferrite's and most parts needed to do a variable SMPS.
The question is: Is it feasible to build a SMPS with something like 0-80V / 2A? Voltage and current-limit should be variable.
If its switch-mode it should be possible to get a lower voltage and a bigger current, right? Like 40V / 4A ?
My thinking is that it will be a bit harder to kill my self if I use the transformer from the Lambda PSU instead of doing a off-line PSU. Would like to learn. Would not like to get killed.
I Think a lot of people here could use a big PSU for testing electronics. If I get something to work I'll of course share schematics, PCB's and any info.
Anyhow. I've had some basic switch mode-curses and I'm an electronic engineer, but I could use some pointers or links to get started. I've got a 100Mhz analog scope and acces to PSpice/Orcad.
Thanks in advance for the help
Regards TroelsM
