will this pre amp be suitable for use with t amps? price is fairly comparible to the autosostruire pre i think. It is fairly expensive but i see the pre and phono stage as things i will stick with longer and experiment mainly with the t power amps. will probs start with a 41hz amp amp1b as stereo power then go mono. or should i jus get monoblocks straight away? as this is ultimately what i want.
http://www.worldaudiodesign.com/wadproducts/series11.html
hi carlos671
build your own tube preamp! it's really simple.
http://diyparadise.com/simplepreamp.html
http://diyparadise.com/etude.html
http://diyparadise.com/12B4pre.html
the first link gives you a powerpoint presentation, showing you how to wire up one. step by step...
donjuan
donjuan
