0.1uF voltage rating 2.5 to 3 times or better if size permit of incoming AC voltage ( from secondary coil of transformer).Alternatively you can parallel another 0.01uF for higher frequency.
0,1 uF
0,1 uF is generaly recommanded. I use Wima MKS4.
Low swiching noise diodes are also welcome. There is a nice article by John Camille about this topic in Sound Practices #7.
Alain
Alain
I experimented some configurations (not simulations!)
A diode bridge should have a behaviur similar to a 1N4007 bridge, I found it best smoothed by 1ohm+22nF // 100nF across the secondary connection to the bridge. It's useless to put a snubber across each diode.
The diode manufacturers say otherwise (when they care to be informative).It's useless to put a snubber across each diode.
mrjam said:I experimented some configurations (not simulations!)
depends upon the transformer -- and the voltage -- the frequency of the resonant circuit formed by the diode junction capacitance, and the leakage inductance, the ESR and ESL of the filter caps. the diode junction capacitance is a function of voltage (that's how we get diode tuning).
you can start off by measuring the transformer leakage inductance, but this is only a starting point...
Sorry, I omitted to say: "in my test configuration" 😀
I trust in my Tek digital storage 'scope! 😉
With this net - in this test configuration - the oscillation is better smoothed.
Are you sure your manufacturers refer to standard diode bridges? ..or you're talking about SBVY or MUR series. In my tests - with my test configuration naturally - the former are best smoothed by a 22nF across each diode. RC doesn't give any improvement.
All I mean is that the RC snubber across each diode is not always the best solution. Let measure it ...but it's reaaaly difficult without a storage oscilloscope.
Next week I will have access to an exceptional tool, a 20000bucks Advantest R3131 3GHz Network/Spectrum Analyzer, so new measurements have to come. I'll let you know the results of the snubbering on the wide RF spectrum.
Hi Jackinnj
---you can start off by measuring the transformer leakage inductance, but this is only a starting point...---
How to ?
How to ?
Let's just look at it as an RF circuit with just R,L and C and the Multisim Bode Plotter -- In order #1 is unsnubbed, #2 uses 1R+22n//100nF across the secondary (as suggested by MRJAM), #3 uses 500R+1nF across each Cjo
forr said:Hi Jackinnj
How to ?
It is only a starting point --
To measure the leakage inductance of the secondary short together the primary leads THEN measure the inductance of the secondary.
Hi Jack,
for me and any others that might mis-interpret your posted sims. Please confirm which is best and which is worst.
- Power Supplies
- Value for capacitors over the diodes to prevent from high frequency
