We are pleased to announce that the V series of loudspeaker. The V1 is the first and uses the VWR126X and the new LD22 tweeter and fits into a standard .25 cu ft cabinet. If you don't want to build your own then the Parts Express cabinets are available. These were used for the products development. This driver configuration also works as the top part of the V3 (with a different crossover) where the top cabinet sits on a 1.0 cu ft cabinet containing the LDW7 ported woofer.
From now till Christmas we are including the Mills resistor option at no charge for all orders.
Other upgrade options including cabinet damping material, wire, and Duelund resistors and Obbligato and Mundorf capacitors are also available. The various Parts Express 0.25 cu ft cabinet pairs are also available.
New CSS speaker kits as shown below photo.
V1 Mid Tweeter
V2 Mid Tweeter Mid
V3 Tweeter Mid Woofer
V2MLTL Mid Tweeter Mid
Now the acoustic info for the V1 speaker kit.
V1 frequency response from 0-40 off axis 200hz and up
V1 frequency response from 0-40 off axis 200hz up 5db graph.This is the same as above but rather a closer look in scaled view.
V1 frequency response from 0-40 off axis MOUNTED ON WALL.For those wanting to use the V1 speakers mounted on wall this shows you the response 0-40 off axis.Very good response when using the V1 as a wall mounted speaker of positioned up against the wall.
Below is the impedance for the V1 which is shown 3 ways below.
First Ported V1 impedance with a PVC port
Second Ported V1 impedance with a slot port
Third Sealed V1 impedance
V1 speaker kit has many options for crossover upgrade options contact CSS for those options.
V1 speaker kit
V1 speaker kit with Acoustic foam and damper pads
V1 speaker kit with Mills resistors plus 16g Teflon Silver wire
V1 speaker kit with Mills resistors Obbligato 630V capacitors with 16g Teflon Silver wire
V1 speaker kit with Dueland resistors Obbligato 630V capacitors with 16g Teflon Silver wire
V1 speaker kit Mills resistors DHLabs 14g wire
V1 speaker kit Mills resistors DHLabs 14g wire Obbligato 630V capacitors
V1 speaker kit Dueland resistors DHLabs 14g wire Obbligato 630V capacitors
V1 Mid Tweeter
V2 Mid Tweeter Mid
V1 speaker kit
Thanks Al. The excellent off-axis response contributes to the superb imaging and
a 3-D presentation.
Bob
a 3-D presentation.
Bob
Cherry and Maple cabinets from Parts Express.
