Mainly just on an experimental basis, I would like to try the Hypex 400-Watt module with a half wave power supply, just so I can try it out before spending on the ideal transformer. Any huge pitfalls? I know there is a disadvantage in terms of ripple voltage.
Along the same line, I notice that the UCD400 module has a 65 dB ripple rejection. How does that stack up against typical Class-AB?
Half-bridge or half-wave? Those are two different things from my understanding.
I think Brian got the impression you meant half-bridge as in a single supply. To me it looks like you meant half-wave as in only two diodes in the rectifier and a single secondary, but still a dual supply(voltage doubler?).
Which is it?
Which is it?
theAnonymous1 said:I think Brian got the impression you meant half-bridge as in a single supply.
Whoops! For some reason I read that as half power supply and thought fdeck meant single rail supply. I need to read a bit more carefully... Thanks for catching that Anonymous1.
fdeck, using a full wave voltage doubler with a single secondary transformer is doable but certainly not the best way to get a split rail supply.
