Using two 48V 3A POE adapters for the PSU of a MOSFET amplifier?
Hi all!
This is a bit of a 'lazy/cheap/mad' idea of mine that on paper looks fine, but I was wondering what the reality was - has anyone tried this?
I've two spare but fettled Maplin MOSFET amps that I want to pop into an old Sony TA-F6B hulk (I was never really comfortable with the PSU or BJT power amp), and I have two options:
Plan A:
Use my existing spare 300VA toroid + a new softstart relay + resistor (ebay £4+) with new capacitors, perhaps twin bridges to separate the MOSFET supply and the amp PCBs...
OR Subversive plan D:
Buy two cheap 48V SMPS PSUs, hopefully quiet ones - yes, it's a lottery, but perhaps the POEs will do, and hook together as a bridge. That in theory gives nearly 300W too, and saves all the bridge and cap work and cost, but at the expense of separate rails for the OP transistors. In a way this is sort of more in the spirit of the original...
Plan Da:
A variation on this theme is to use a small 48ish Vdc split analogue supply for everything else, perhaps +/-35-40V would do as it's all regulated down to +/- 30V anyway, and the POEs just to power the MOSFETs themselves (the top source and bottom drain).
All thoughts welcome - thanks in advance! 🙂
