Using the SMSL SP200 to drive a 16 Ohm compression driver
Hi All. I’m looking for some input on the viability of using the SMSL SP200 THX 888 headphone amp to drive a 16 Ohm compression driver in my two way speaker. My two way uses an Eminence Kappa 15C in a Peavey FH1 bass bin, and Renkus-Heinz SSD-1800 16 Ohm compression drivers on Altec 511B horns. The compression driver will be used for frequencies above 400 Hertz. The specs for the SMSL SP200 show that the amp
Is rated at 6000 mW into a 16 Ohm headphone. This would seem to indicate that he SP200 would be able to do the job, as I would be unlikely to use more than 2 Watts normally, and as the compression driver is 16 Ohm, but I figured it’s best to ask just in case I’m missing something prior to ordering the amp. I have attached the spec sheet for your consideration. Any input would be appreciated.
