using T-amp to powered up active Jordans
hello,
i'm relatively new to T-amp, after reading few posts in here, and reading michael mardis website, it seems very promising 🙂
i'm planning to build jordan system with jx92s and jxr6hd or j6t from markaudio, i used the jx92s before powered up with nad, but now i'm keen on building simple TL system with the help of j6t or jxr6hd for the top end, might be similar to what jim griffin wonderfully done 2 way jx92s with aurum cantus ribbon.
so if i want to powered up each driver, and mightbe without using any xover, is there a simple way to filtered the drivers or need to add x-over?
and what kind of active xover that will suit the T-amps, and i see few kits from 41hz.com it seems they have high powered t-amp also, might be good to fire up subwoofer also.
anyway, please give opinion freely, or anyone have done this setup before?
thanks
best regards
henry
