Has anyone attempted to do this.....just regulating the driver board B+ and B- while leaving the current source and output stage on the rails???? Just curious what this might do to the character of the amp. I would think the S/N would be alot better. If this is at all possible.....
Mark
Mark
Mark,
Here’s an early thread where they talk about regulating the rail voltages with comment from Mr. Pass.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=172&highlight=aleph+regulator+power+supply
Here’s another where the subject of regulation is discussed briefly along with other noise reducing ideas including extra filtering for the front-end rails. This thread is where HH introduced the LM329 front-end current source (now known on the forum as the HH CCS).
http://www.diyaudio.com/forums/show...ge=15&highlight=aleph noise turn&pagenumber=1
This is an interesting subject. I hope other will provide input to this thread.
Rodd Yamashita
Rodd Yamashita
It can be done, but would be backwards in a sense. A differential has a built-in immunity to noise and such (CMRR) on the rails, whereas the output has comparatively poor CMRR.
Of course, you could argue that anything that manages to effect the front end will be amplified more than anything in the output stages.
If you build a separate rail for the front end I'd suggest leaving it on all the time. It only draws a watt or two and the amp would be that much closer to being warmed up.
Grey
Grey
You can also check this: http://www.diyaudio.com/forums/showthread.php?s=&threadid=3051&highlight=aleph+front+end
