Using only one VC of a DVC woofer?
If I have a dual voice coil woofer that has two 8 Ohm voice coils, what effect on the T/S parameters would only using one of the voice coils have?
I'm guessing power handeling would go down, as would the efficiency (at 2.83V), but other than that what else? The efficiency at 1w would stay the same, correct?
Also, I read somewhere but cannot remember where that when doing so one could place a resistor across the unused voice coil to tailor a Q factor, not sure which, anyone know of this?
I ask because I'd like to use it with an amp that cares not too much for 4 Ohm loads, if I have to I'll put them in parallel, but the power of the amp would drop...
