I have some spare 700as2 modules that I would like to make use of. Ideally I would like each module to power one sub.
Can anyone confirm if I can use only one channel of the 700as2?
Each sub will receive one side of a stereo signal. It would be single ended input, single ended output. Just using one channel of each module start to finish.
Many thanks
Many thanks
You don't want a stereo signal for subs. If you do, you will get phasing issues in a room with pockets of no bass.
Yes you can use just one channel if you like.
One channel is no problem.
Perhaps you would like to short the none used input... but that's picky...
