I have a nice stereo pre-amp that uses two 6J1 tubes. Got it from China.
I have a nice little 'pill' that contains a blue-tooth capable IC amp powering two speakers rated at 3 watts each. It is meant to take input from bluetooth or a plug. It is powered by a rechargeable internal battery that can be recharged from a USB port.
I would like to use the output from the IC amp as input to the tube amp. Will this be feasible or are there special precautions to take? I plan to power two 3-watt speakers.
Cent13
Cent13
I notice quite a few people have looked at this question. Is this a bad idea, one that will not work? Or are there precautions I need to take? Or is the tube amp better at feeding a signal into the IC amp?
Nobody understands what you mean. In order to get 2-3w of power you need at least a dozen of 6J1 tubes in parallel.
Hmmm. Okay, so the tube amp with a single 6J1 per channel won't provide that much power, not enough to drive a pair of very small speakers. Best to feed the original signal into it, then take its output and feed it into an IC amp.
I am new to tube amps, obviously, and do not know their limitations just yet.
