Usb Tt
From "The Paper of Record" the USB Turntable:
January 21, 2007
Novelties
The Turntables That Transform Vinyl
By ANNE EISENBERG
LONG-PLAYING records are gathering dust in the homes of many music lovers, who hope to hear their contents one day on a CD player or iPod.
Now, an updated version of another audio relic, the phonographic turntable, may provide a fairly inexpensive way to do that. Two new consumer turntables on the market at $200 or less connect directly to computers to transfer cherished vinyl to MP3 files and CDs.
The machines aren’t for audiophiles who have the skill to rig their own systems with special cables and preamplifiers. But they may offer a doable way for nontechies to thrill again to their favorite bit of analog Beethoven or Dylan.
Learning how to use these systems takes time — up to three or even four hours. The turntable has to be assembled, and the LPs cleaned carefully to remove the dust of ages — two jobs that those over 30 might remember well.
Then the recording software, which comes on a CD, takes about a half-hour to set up properly — or three times that if you skip the “frequently asked questions,” as I did, and then sheepishly return to them when you get stuck.
The software requires some attention even after you learn its ways. For example, it can’t automatically detect the end of each track between two songs or movements of a symphony. You have to mark these spots yourself in the program before burning a CD or making an MP3 file.
Still, once the learning curve is vanquished and the sounds of much-loved old recordings fill the air, you may wonder why you waited so long.
One of the new turntables is called the Ion USB or, more formally, the iTTUSB ($199 list price, about $150 on the Web through a site like Amazon.com). Made by Ion Audio, it works with both PCs and Macs. This lightweight plastic turntable plugs directly into the USB port of computers; inside, it has a preamplifier to bolster the sound, which is digitized and then sent to the computer through the USB cable.
When the Ion turntable is removed from its box, the rubber belt that drives the platter must be threaded into place, and the tone arm put together and balanced so that it produces just the right weight on the record. Be sure not to discard the Styrofoam blocks after you unpack the device: the tone arm and its counterweight are tucked within them.
The software goes on next. The Ion uses a venerable and free program called Audacity, which can do many jobs — like eliminating some scratches on the recording. Installing it is easy, though a few instructions in the Audacity manual are in high geek, particularly those that guide you through changing the settings so the internal sound card on the computer will be used for playback rather than the turntable, which has no speakers. The frequently asked questions, downloadable at the Ion site, www.ion-audio.com/ittusb_FAQ.php, are invaluable here.
One of the trickiest parts of the recording procedure is low-tech: cleaning the records. Unearth your old LP cleaning brush or buy a new one and carefully run it over the LP. And make sure that the turntable is on a level, relatively vibration-free surface.
When you press “record,” you’ll see the digitized wave forms of the music traveling across the monitor and hear the audio version through the computer speakers or headphones. (Ion suggests trying a short section of an LP as a test.) If you are ambitious, you can edit the file, deleting some of the scratches, for instance.
Once the recording is done, the album must be divided manually into tracks, by marking the beginning and end of each with the computer mouse. If you can’t tell from the wave forms where the break is — they drop off when there’s silence — you can always check by listening to the recording.
In Audacity, each track is stored as a separate file; if you are making multiple tracks, you send each on its way as a .wav file to your hard disk. The manual was too geekish on this step, but the frequently asked questions explained it clearly. Once the files are on the hard drive, they can be burned quickly to a CD. The Ion will also convert 78-r.p.m. records, as well as cassette tapes.
Another new turntable, Audio-Technica’s LP2Da ($170 to $199) works with PCs but not with Macs. And it has a sturdy dust cover, unlike the coverless Ion. The Audio-Technica’s tone arm comes assembled and can be set to raise and lower itself from the turntable automatically
The Audio-Technica model has a pre-amplifier, but no USB connection. It plugs into the computer the old-fashioned way: through an analog line input jack. That means that it won’t work with many laptops unless special hardware is bought, for laptops typically have a jack only for a microphone.
THE accompanying software, Cakewalk Pyro, is easier to use than Audacity: burning a CD, for instance, requires only one click for the entire LP, while Audacity requires that you send along each track separately. And it includes software for converting .wav files to MP3 files; by contrast, Audacity requires users to download a free plug-in in order to do this.
Ion users may soon have software that is easier to handle: in April, the company plans to replace Audacity with a program that detects tracks automatically and allows recording in MP3 format without a separate download. Buyers of the iTTUSB will be able to download the update at no charge. The company also plans to ship two models that are variations on the basic iTTUSB, both with dust covers.
Of course, there are other ways to digitize old LPs. Commercial services will transfer them, typically for $15 to $50 each, depending on the number of extra services. TEAC makes an all-in-one machine that doesn’t require a separate computer to convert LPs to CDs ($400). It does some automatic tracking, although incompletely.
To see how the new, inexpensive turntables sounded once they were set up, I invited a friend, George Basbas, a physicist, to bring over some of his treasured LPs. One was an old Columbia Masterworks album featuring the countertenor Russell Oberlin. We recorded it on the Audio-Technica turntable, burned a CD from the .wav files, then played both the CD and the LP on the stereo.
We couldn’t tell for sure which was the LP and which was the CD, although many experts probably could. “Any digitization process imposes limits on quality,” said Mark Schubin, a media technology consultant in Manhattan. “Be prepared: it won’t sound the same as you heard it through your analog system when you were playing back the record.”
But the new recording sounded good enough as we listened to Mr. Oberlin’s exquisite voice fill the room, ready to be taken along by CD or MP3 in the car or on a walk, freed after more than 50 years from its vinyl confinement.
