Just finished designing a PC USB scope.
It only works up to 10KHZ but is good enough for repairing amplifiers etc.
It based on a PIC18F4550.
I converted a USB project from Waiting for Friday – Weekend electronics engineering for my needs.
It has a AC/DC switch.
1 meg input impedance.
I used a 4051 multiplexor to switch in one of 8 resistors for gain/attenuation.
The PC display software was fun. You can shift the display up/down or left/right.
It has two movable circles that read off the difference in time and voltage between two points.
I managed to find a working FFT function so I can display frequency content.
You can set the trigger level to be none, positive going or negative going.
You can also set the trigger voltage.
