USB inputs for digital amps?
I presently have a Bantam digital amp with USB input:
Temple Audio Bantam. High Quality Class T-Amp.
It's nice and sounds good, but I'm wondering what's the next step up from this? What kits or modules are available with a similar kind of USB input so I don't have to use a DAC to go through the analog domain? Maybe Hypex, or others?
I keep all my music on a Mac Mini in iTunes, so would like to keep it simple unless there are better ways to get really good digital sound.
All help here appreciated - feel like upgrading for 2012.
Andy
Here is my take on this :
Get yourself a multichannel external soundcard (griffin firewave, Focusrite saffire for firewire or any of the available usb options)
Get "PureMusic" ( CHANNEL D - Pure Music ) This has a built-in crossover of extraordinary quality.
Get a bunch of amps, class-D or otherwise and start experimenting with your active multichannel system!
since you've mentioned Hypex, Bruno has made a point many a times that there's no such thing as a digital amp. eventually you have do do some analog and that defeats the purpose. you need to get the "digital is inherently better" catchphrase out of your head 😉
I do also have an Edirol Firewire FA-101 but I'd assumed I would lose quality using that for audio? I don't know if it does multi-channel. I don't need surround sound, and at present use a full-range speaker unit with no crossover, but might be interested in a 2-way speaker option with a ribbon speaker and a mid-bass.
I don't know if I have this wrong, but I'd assumed that my Bantam USB amp took the digital signal direct from my Mac into the amp input, i.e. no DAC?
andy
The Dac's built into your Edirol are probably of better quality then the one that is build into your bantam amp. you do understand that there is a dac in that amp?
There are many other upgrade possibilities other then multi-channel, for instance you could use lossless compression instead of mp3.
Hi - no I didn't understand that the USB input converted to analog and then back to digital. I build with tubes, and digital is a bit outside my knowledge base.
I'm looking for an audiophile solution that compares with the tube amps I build, so yes, I do store everything in WAV in itunes.
This is all really useful information for me - on a bit of a digital learning curve!
andy
