USB - I2S interface for output and input
Hello,
I want to build my own USB soundcard for Windows 10 with at least 384kHz/32 bit DAC, like PCM5102 or similar, and for at least 192kHz/24 bit ADC.
Now I have XMOS interface, which only supports output. I like XMOS, it sounds good, it has no noise, it works well with Windows 10, which I am using. But the problem is, that it has no input.
I have module with WM8782 ADC, which is 192kHz/24 bit ADC with I2S output. I don't know how to connect it to my computer. I was searching, I found interface CM6631, but I didn't found any module, which has wired input interface. Only output one. I also found that some guys overclocked it's output to 384kHz/32 bit, but I didn't found any modules or projects, that uses input and output interface. Do you know any? How can I use CM6631 as input?
Second chip I found is CM6635, which supports I2S input and output at 768kHz/32 bit, but I didn't found any datasheet or projects with it. Do you have any informations about this chip?
Thanks.
I would recommend the MCHStreamer over the DIYINHK. Bth are xmos based, but the minidsp offering is from a well used manufacturer that finds its place in numbers of OEM products. the same cannot be said for the DIYINHK offering. neither are top shelf designs, but the minidsp stuff (particularly their more recent products) is far more competent IMO.
I have and use their 2x4HD DSP and USB module. its been pretty solid.I used it directly for a while; with good success, the software is pretty good. i'm using its i2s out with external dacs, which was always my plan; not because I found it lacking after buying it.
From what I gather it takes both DAC and ADC I2S PCM up to 384kHz/32bit but then it says it outputs only 32bit regardless the input. Does this apply only to the DAC? Can it support your 24bit ADC? I suggest you better ask them to be sure.
I never had a look on that, they should exist though. But generally speaking, an ADC is more tricky than a DAC to make it work as it is very likely to require I2C control and you will be pretty much alone with that. However, WM8782 seems to be a nice exception!
