USB Glitches with W98SE
I've made a PCM2707 based USB to SPDIF converter to use with an old P2 laptop running Windows 98SE. It works fine, except for occasional irregular glitches which seem to be caused by Windows losing attention.
Is this a common problem with Windows 98SE, or is there a way to make the USB audio a higher-priority task for the CPU?
