USB Digital interface xmos 208 Support PCM32bit/384K DSD256
I'm using PC USB out to feed my AK4396 based DAC.
For USB to SPDIF conversion I use a CM6631a based usb to SPDIF converter.
I'm wondering if a change of the digital interface into xmos 208 384K (see link) would improve the sound.
USB Digital interface xmos 208 Support PCM32bit/384K DSD256 output coaxial optical IIS(RJ45) AES/EBU
USB Digital interface xmos 208 Unterstutzung PCM32bit/384 K DSD256 ausgang koaxial optische IIS (RJ45) AES/EBU|Digital-Analog-Wandler| - AliExpress
There are good reviews of the unit on audiophonics.fr
AUDIOPHONICS XMOS U208 Interface digitale USB 32bit / 384kHz AES / I2S 2x TCXO Alimentation 230V OTG - Audiophonics
There are three versions of this digital interface available. Does anyone know differences soundwise?
There's also a much cheaper digital interface on Alieexpres
XMOS XU208 AK4490 USB DSD256 DSD Native 384K DAC MAX9722 Kopfhorer Verstarker|Heimautomatisierungs-Sets| - AliExpress
But I'm not sure if it's of the same quality.
Many thanks in advance, for helping me.
jockel77
