Hello,
While working on my android tablet HU for car I accidentally desoldered smd component that is in series with D+ line for usb, there is also the same one for D-, but there is nothing writen on it. I checked with microscope...
I measured the same smd from D- and it`s not a diode, it`s resistance is 0.2ohm.
It`s black and I think it`s a 0402 size...
So ok I tought it`s a black smd, its got to be a resistor, so I soldered 0.2ohm 0805 smd resistor instead of it... But I get error message "Device descriptor request failed" in windows...
I can confirm that I get 5v on VBUS and GND if I short ID pin to GND (OTG mode), I have 96,5kOhm resistance towards the GND from both D+ and D- lines...
That would confirm that everything is soldered correctly, no shorts...
That being said, that SMD component must be something else...
I can find no schematics only of any phone, tablet...
Does anyone know what would it be?
It`s a black SMD, I think 0402 with resistance of 0.2ohm in series with D+, where is another one in series with D-, followed by common choke...
Thank you for your time and help
0.2 ohms is very low. Are you allowing for your meter lead resistance i.e. the reading you see with the probes shorted?
I can't really say what the part might be but something that low could even be a 'zero ohms' link or a fuse.
You are right, that is the lead resistance, my bad... I don`t know how I forgot to measure it.
I tryed to bypass the resistor and it does not work, that`s telling me it is not a fuse or zero ohm link...
Well I hope someone will know whats going on... I cant find any schematics of usb simmilar to my circuit online, it`s frustrating...
It could be. It`s used for minimizing EMI right? But usb didn`t work bypassing it. Do you think it shouldn`t?It might be a ferrite bead.
Yes, the ferrite bead is used for EMI reduction, at this point you may need an oscilloscope to at least see if you have any data on the usb connector, failing that you're going to have to source the schematics for the tablet.
- General Interest
- Everything Else
- USB circuit android...
